im putting two 50 min episodes onto a DVDr from VHs using TMPGenc and am reducing the bitrate by half to fit them onto i disc for encoding , This maybe doing the samething but if i could encode at the best bitrate and then DVDshrink the final authoured file (both episodes) down to fit on 1 disc would i be doing exactly the same thing as reducing the bitrate in TMPGenc or could it produce a better end result ?![]()
TmpGenc is an encoder, DVDshrink is a transcoder. They work in different ways attempting to get the same result. Using an encoder with the correct bitrate from the start (and other settings correct for the situation also) should produce better results than using a transcoder to shrink, especially if using 2-pass VBR or CQ mode encoding. But quality is very subjective so in the end only you can really decide which is the way to go.
Any such thing as a raw capture?
By VHSMadness in forum Capturing and VCRReplies: 12Last Post: 24th May 2011, 07:43 -
no such thing as an asf plugin?
By uglijimus in forum Video ConversionReplies: 10Last Post: 10th Oct 2009, 22:56 -
Why is there no such thing as 60FPS above 320x240?
By Syclone0044 in forum Newbie / General discussionsReplies: 29Last Post: 28th Sep 2009, 14:22 -
The One Thing That Can Save HD DVD
By cracula in forum DVD & Blu-ray PlayersReplies: 12Last Post: 19th Feb 2008, 12:52 -
Is there such a thing as DVD-RW DL disks?
By the_importer in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Dec 2007, 04:28
