when i try to load the mp2 in the main "open" of ffmpeg, mplayer bounces about in the dock then freezes, i have to force quit mplayer to get ffmpeg back.
this also happened when i tried to load an aiff to convert it to mp2, mplayer would freeze. do i need to reinstall mplay, it seems to work fine for video its only with audio that i have problems.
im trying to do a simple conversion of audio and it wont load the mp2 file (which was demuxed from an mpg using ffmpeg)
im trying to create a dvd using sizzle and mpeg-1 type files with 48k audio, is this the same as the s/vcd>dvd funtion in the registered version?
as that didnt work
thanks
ds
Results 1 to 10 of 10
i tried reinstalling the whole thing getting fresh mplayer etc
but when i run the command line it still give the same size
i have the mplayer osx but that looks like its a standalone player
when i found the files on sounforge there were a selection to choose from including one marked for use with ffmpeg, do i go for the ffmpeg bundle?
but i have found a work around, when i select the mp2 and then mplayer crashed, i force quit mplayer and that lets me use ffmpeg again, i then select from the presets audio file to mp2 (even though i knew that, perhaps ffmpeg thought it was a video file hence the mplayer thing) and that seemed to work, without selecting the preset it wouldnt.
ds
Hey Major,
I have the exact same problem where mplayer freezes up when trying to open an MP2 file. Force quitting mplayer and getting info on the MP2 file gives:
Audio : Mpeg 1 layer 2
Estimated Duration: 58:50.63s
224 kbps 44100 Hz
Frame size: 731 bytes
Stereo, No emphasis, copy
Checking mplayer as you suggested in the previous post gives:
-rwxr-xr-x 1 root wheel 4658648 Sep 10 2003 /usr/bin/mplayer
I went ahead anyway and downloaded a new copy of mplayer (same size, new mod date, obviously) and reinstalled all the engines. Still mplayer hangs. So I then reran the ffmpegx installer (v. 0.0.9b btw), same response. I tried both dropping the MP2 file on the ffmpegx icon in the dock, and using the Open button.
I next tried the trick of force quitting mplayer and going ahead with the conversion to 48k. It's queued up at the moment so I am not sure if this is going to work or not - but it looks promising.
I know I have done this conversion before - don't know what version of ffmpegx I used, obviously it was not the currently installed version.
Hope the info helps, it's a great app and your response to problems is also great.
Thanks, CGuy
I have the latest mplayer, its byte count matches major's. Same problem, but when I force quit mplayer and get Info on the mp2 in ffmpegX the box reads, simply, "Alert:"
This will be an even bigger issue now that iTunes no longer accepts and converts .mp2s.
The whole reason I'm here.
Hope this helps,
-MooVMaker
Forgot to follow up on this. The conversion did work as I detailed it in the above post.
And, BTW, I tried another mp2 conversion where mplayer froze up. I didn't force quit it immediately - in fact I was in the middle of something else and didn't get to it for awhile. After about 2-4 minutes mplayer ended up quitting by itself and everything was back to normal. Strange, huh?
CGuy
How to mux M2V and MP2 ?
By aussie74 in forum Authoring (DVD)Replies: 5Last Post: 19th Mar 2012, 08:17 -
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 23:28 -
Extract audio from MP2 and more
By txl in forum AudioReplies: 7Last Post: 30th Jul 2009, 07:49 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 06:32 -
Vodai MP2 codec
By ljs3 in forum ffmpegX general discussionReplies: 1Last Post: 9th Jun 2007, 03:38
