I have problem capturing analog
video using the canopus advc 100
and virtual dub
However I am able to do so
using Ulead DVD movie factory
Can someone who has been successful in
doing so, show me the way?
Ram
What happens when you try to capture with Virtual Dub?
Hello. -
I have never been able to capture through my ADVC-100 with VirtualDub nor have I been ever able to play anything captured with my ADVC-100 using virtualDub. I read once in the forums that to play a capture, I needed a Panasonic codec or something but it has never worked. I currently use MSP 6.5 Director's Cut. Works beautifully.
Look in the how-to guides for video capturing with Canopus ADVC-100.
Basically, I am capturing into WinDV (freeware), and then I do my editing and conversions with VirtualDub. Default number of frames for WinDV capture is about 12:30 or 22500 frames or 2.7GB. I am saving my DV AVI files from Canopus for archival purposes, and I want to fill my DVD-R's, so I either drop frames to 18000 (10 mins) or bump to 36000 (20 mins). I am converting to DivX5.1.1 video with MP3 audio using VirtualDub, and saving the DivX encoded files for my viewing pleasure.
I am capturing 8MM videotape (home movies). If you have a single audio cable going from your source to the Canopus, your audio levels will be too low. Buy a Y-cable (e.g. Radio Shack, Fry's, wherever) and connect your mono output to the left and right jacks on the Canopus. Audio levels should be fine then.
Since I am more interested in quality than DVD-R space usage, I am converting to DivX at 4000kbps 1-pass.
Enjoy your ADVC-100. It's the best video capture device I have ever used.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
