What's the easiest way to copy a video from a +R disk to a -R disk? Can I just do a straightforward disk-copy or will it have to be converted somehow?
I tried it with DVDDecrypter in ISO mode....didn't work. The only way I can do it on my PC with my LG burner is to use my B's Recorder Gold that came with the drive. I just copy "on the fly" and it works....for some strange reason when it wont in DVDDecrypter.
Is that just a straightforward diskcopy or is it doing any processing of the data?
Put one disc in your reader.
Put a blank in your writer.
Hit "copy" in your program of choice.
If this doesn't work, there is something drastically wrong with your computer.
- Gurm -
THe macrovision is already removed from the +R, copy on the fly drive to drive or simply copy the files off the disc into a folder and burn. DvdDecrypter may not support your drive for ISO mode, theirs no need to use if anyway, you can make an image in NERO or RecordNow Max and burn it if you do not have 2 drives.
All I know is....the ONLY error message I ever received with DVDDecrypter was when I used ISO Read Mode from a +R disk then tried ISO Write Mode to a -R disc. Didn't work. Maybe it was a fluke or a bad -R disc....not sure.
Copying DVD movies with a Sony VRD-MC6 Multi-Function DVD Recorder.. help?
By madeyeX in forum DVD RippingReplies: 14Last Post: 17th Dec 2014, 20:36 -
Copying a DVD
By grominnetto in forum Video ConversionReplies: 5Last Post: 17th May 2010, 20:31 -
copying from UDF Video DVD to new DVD HELP please.
By SusanBFH in forum Newbie / General discussionsReplies: 13Last Post: 27th Apr 2010, 13:47 -
Free DVD encrypter for copying DVD's? DVD43 won't work for me
By marcias_70 in forum DVD RippingReplies: 1Last Post: 2nd Feb 2009, 03:09 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 04:44
