I've got some VOB's of 2 movies I've made, and a menu I made to link the two. I needed to compress them all to it onto one DVD using dvdshrink, but I was having problems and ended up having to compress the VOB files alone, without altering the ifo etc. files, and as a result when I come to burn, my writing software does a quick check and claims the disc is >4.7Gb - d'oh! how can I easily create some new ifo files so that I can still use the disc and its menus? It doesn't seem quite so easy using standard authoring packages - for example dvd author seems to split each chapter of each video into separate video clip![]()
I've seen a guide at www.dvdrhelp.com/forum/userguides/120021.php but it seems to only cope with one VOB file and no menu.
thanks![]()
Results 1 to 1 of 1
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 02:06 -
Can I create an .IFO file from .VOB files?
By Madcap in forum DVD RippingReplies: 7Last Post: 15th Aug 2010, 14:57 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 03:07 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 18:19 -
creating .ifo from .vob files and keeping menus
By vishalpatel1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2007, 07:40
