Got an old 512K Apex AD-1100W with the Nerd-out BIOS update (still w/ Macrovision). This sucker will play VCD/SVCD/XVCD/XSVCD/DVD -- Everything I need! Unfortunately, It's gotten to the point where the NO DISC error is starting to appear when trying to play DVD's. I've removed the clip and re-aligned the ribbon cable, but I have to open it up every 2 weeks and re-position the lens assempbly in order to get it to read DVD's. This is just getting too frustrating.
What inexpensive (approx. $50-$60US) DVD player can be found that will play the variety of media and file types that this good ole boy did?
Will the Newly re-released Apex AD-1100W's?
The Apex 1110W's?
The Norcent models (which)?
Any others?
I would appreciate recommendations, as there are so many models and variables with the search results. Please comment and let me know if a firmware mod would be required. Don't really care if it is reqion Free or Macrovision disabled as all I want is to play my CD-R's and DVD's (no recording).
Thanks !!!
Cyberhome 300 is even better than the Apex 1100. I own them both.
Find the Cyberhome for $40 at WalmartWant my help? Ask here! (not via PM!)
LordSmurf,
Thanks. I had heard about the Cyberhome, but was not really sure if it was as versatile as the AD-1100W.
How long have you had yours? I've read about some issues with the motor not holding up due to the higher speeds/heat generation of VCD/SVCD playback (as opposed to slower speed DVD). I will be using it for approx 85% SVCD/VCD and 15% DVD playback Do you use it heavily for VCD/SVCD? Any issues?
At $40.00 -- this certainly sounds like a great value !!
Thanks!
How can I replace one subpicture with another?
By doctorjellybean in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2009, 08:59 -
How can I fix the playback time of a title when replace the VOB?
By Massa in forum Authoring (DVD)Replies: 5Last Post: 17th Jan 2009, 14:25 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 14:16 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
Help deciding what to replace my old TV with
By LT9000 in forum DVB / IPTVReplies: 8Last Post: 1st Sep 2007, 02:21
