I have Nero 6 and have been having a ----ty time trying to format a dvd for data. I use Nero6 InCD and format then try to drag and drop files on to the dvd, hangs up. But if I copy the files ok, but then try to delete the files, can not, read only. What am I doing wrong? I want a DVD data disc I can store, drag & drop, delete data on, how do I do that.![]()
Sounds like you need a rewritable disc (DVD+/-RW) for what you are trying to do. Especially since you want to delete files.
Make sure you get a disc compatible with your DVD drive (+ or -).
Formatting a DVD+RW
By V Bot in forum MediaReplies: 10Last Post: 28th Jul 2009, 15:09 -
Formatting DVD+RW on Linux
By daithi_dearg in forum LinuxReplies: 4Last Post: 13th Mar 2009, 19:46 -
Formatting a rewriteable DVD?
By c5vetman in forum MediaReplies: 3Last Post: 27th Mar 2008, 03:05 -
Formatting a dvd-rw 4.7gb
By IOMEGA in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 15:56 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 13:51
