i have ab avi that plays in full screen,i want to convert this movie with tmpgenc to put on dvd.i usually tell it to keep aspect ratio.how do i tell it or can i tell it to make it widescreen?
did i explain that right?
is this possible?
You should just keep the aspect ratio. The only way to make a full screen frame into widescreen would be chopping the top and bottom of the screen to fit a widescreen aspect ratio. That means the people's heads in your movie would be chopped off and the same for the bottom portion of the screen.
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 22:31 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 12:41 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 16:52
