Iīve been able to capture VHS tapes to the computer and put them into a good quality MPEG2 file using Studio 8.
However, when I captured a video from my sony handycam I got into the trouble of having to deinterlace the video to be able to watch it with a better quality.
The problem I have is:
when I capture a 2 hours video using Studio 8, at a bitrate of 3000 and a resolution of 640 x 480, I get an AVI file which is 21 GB large.
Then I open virtualdub, select the deinterlace filter and huffyuv compression. When I try to save the file and the computer starts to process the new AVI file big the estimated file size goes up to 92 GB.
Right now Iīm using huffyuv 2.1.1, because when using the huffyuv 2.2.0 I couldnīt open the final AVI file on any program (system always crashes).
Now the question: why Studio 8 can put 2 hours of tape in a 21 GB file and when I try to process the file in virtualdub it goes up to 92 GB? (without compression it goes up to 200 GB)
I simply need to pass the deinterlace filter to get a better image. I donīt wanna change the resolution right now, just apply the filter.
My system:
DC10+
P4 2.4GHz
512 MB DDR 333
120 GB 7200 133
Ti 4800
Iīm checking AVISynth right now to see if it can help me.
However the question still up: why virtualdub, even with a hyffyuv compression activated generates a file 90GB big if studio 8 gimme the same ammount of VHS time in 21 GB? -
I think I found the answer myself.
When I use my DC10+ in Studio 8 I canīt select any kind of compression codec. Studio 8 must be using something default which so far I donīt know what it is.
Huffyuv 2.2.0 could compress a 21 GB AVI file into a 30 GB one, but I couldnīt open the AVI to work on it later. Every single software I have would gimme an illegal operation.
I saw in the forum that some people were having problems with this 2.2.0 version and were saying to stick with version 2.1.1. This time I could work with the AVI file, but the size went way up to 90 GB.
Last night I gave a try on the PICVideo codec. Now the file basically got the same size of my original capture and also works on everything I got.
The quality in PICVideo is set on 18 and the final result is good enough for me.
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 06:40 -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 15:47 -
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 16:05 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56 -
Please Help! Can't Get VirtualDub-MPEG2 file size down!
By dano187 in forum DVD RippingReplies: 2Last Post: 26th Jun 2007, 19:15
