  1. i ripped my first dvd to the hd using dvd shrink, i now have a folder full of vobs and other misc. items. what program do i use to assemble those files so i can burn them? and from there can i use nero or dvd decrypter to burn then?
    thx
    jaertt
  2. I use nero to burn them it works great for me
    Apr 2002
    The State of Frustration
    Here's your guide.
    Hello.
  4. tommy knocker - thx for the reply but that site is down, i will continue to check it thou.
    I have no problem doin research on my own, i just dont know what i'm lookin for here, so if there's any other idea's that you have i would greatly appreciate.
    thx again
  5. You could use ImgTool Classic (freeware) to make an ISO image. Real simple, there's even an option is settings to have DVDDecrypter burn it for you.
    Pull! Bang! Darn!
    Apr 2002
    The guide I linked just has you put all your authored files into the DVD-Video VIDEO_TS template in Nero's wizard, and burn.
    Hello.
  7. Omg, there is an endless amount of guides on how to do this, and I'm almost definately sure that this question has been asked many times before.
    Put the disc in, use dvd shrink to shrink on hdd, drag files into VIDEO_TS folder in nero or nero express, burn.
    It doesn't take long to search you know.
  8. thx to everyone that HELPED me.
    tommy knocker - the tutorial was right on point man, my first two burns have been a success thx to you.
