  1. just got myself a DVD burner 2 days ago and would like some of u more experienced ppl to clear up some things for me
    I understand that most comercial DVD now days are dual layerd DVD-9
    that are produced in a machine that presses the 2 layers together
    which makes it impossible to do a 1 to 1 copy unless you split it to 2 DVDR's
    what I would like to know is, approximately how much compression to done to the video/sound stream of a DVD when it's backed up to a single 4.7GB DVDR. I'm just talking about the main movie and a single DD5.1/DTS audio stream, no extras what so ever.
    what's the quality like? and I'm not talking about watching it on a dinky 13"
    but on a 42" or larger WD HDTV
    lastly I need to know how much computing power is needed to do the DVD backup. I'm going to install the drive on a P3 800 with 512MB RAM, is this feasible or will it take decades?
    thanks!
  2. Originally Posted by syphon00
    Without all the extras and by creating a simple selection menu I have did movies without much, if any, compression. I can think of projects I've done without any. Usually... 15-30% is probably a normal number. It will depend upon the movie. Some more.
    what's the quality like? and I'm not talking about watching it on a dinky 13" but on a 42" or larger WD HDTV
    @15% you won't notice the difference. DVDs are usually high quality and they shrink well. I've put 2 movies on 1 disk and had to compress like 50%. Then I would answer "yes, some".
    On that machine probably decades. (just kidding) You can cut as many corners as possible to speed things up. Rip just the main movie with DVD Decrypter to a HDD folder. Author the ripped vobs with TMPGEnc DVD Author with a very simple menu, then shrink with DVD Shrink for a custom (max file size) fit, then burn. Maybe it won't be too bad. Just set it up and go to bed. It'll probably be done when you get home from work tomorrow evening. haha. (Just kidding again)
    In other words, don't shrink it any more than you haft to because that process is probably going to take the longest.
    Thanks!
    You bet
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Check out the guides on the left....especially the one for DVDShrink (I like the old version 2.3 better). Awesome program and if you take "movie only" in re-author mode....the compression needed (if any) will not be noticable to most people.
    Convert what DVDShrink gives you to an .IFO file with IFOEdit (also free).....then burn the .ifo file with DVDDecrypter (FREE again) in ISO(same as IFO) WRITE MODE.
    You'll get a DVD that auto starts the movie as soon as your DVD player recognizes it as a DVD.
    All free and I learned it all from the guides on the left.
    Good luck to ya....and have fun.
