Hi all
Does anyone know of an alternative for the god awful software that comes with the ADS USB 2.0 capture box? I usually transfer to my main machine with the ATI AIW as per LordSmurf.com guides (works great!) but some VHS (even with Sima SCC in line) wont transfer properly. Is there other capture software that recognizes USB 2.0 devices?
Thanks!
Maybe it would help if you listed which software you feel is so terrible. All of it? What?
Hello. -
No, not "naturally." In my opinion, Cap Wizard "bites the left one" as well, but I think Video Studio 7 does a pretty good job, once you edit the HerzCap.ini file to give you frame loss data.
Hello. -
Ok, now you lost me.
I didn't bother to install anything but capwiz as I use Vegas 4.0 and DVD Architect to edit/author. I really don't need to edit, I just want to capture interlaced. I was just wondering if there was other software to use for capturing that would work with a USB interface. Vegas does not.
Thanks for the help. -
Ulead's DVD MovieFactory and DVD Workshop can capture from the ADS Instant DVD device as well.
[quote=I didn't bother to install anything but capwiz[/quote]
The ADS usb Instant Dvd-2 comes bundled with thier own capwiz which only captures, plus Ulead MovieFacory-2 and VideoStudio 7se which capture, edit and burn. While the software may not meet the needs of advanced users, they work great for us normal users.
Why bash something you did not even install much less try ???
As far as I know they are the only software that will capture form the device. Ulead is supposed to working on a plug-in to enable all thier software to be compatable -
From what I see as the bundled software, you have Video Studio 7 SE as well. It can capture from ADS IDVD USB 2.0 as well. You won't see the dropped frames displayed in VS7 unless you edit the HerCap.ini file.Originally Posted by BlazeyHello.
ADS Tech Instant DVD
By bolintx in forum MacReplies: 7Last Post: 3rd Aug 2008, 03:32 -
USB Instant DVD
By bolintx in forum MacReplies: 1Last Post: 31st Jul 2008, 15:17 -
Capturing using either ADS Tech Instant DVD or DVD recorder ...
By CaptainChaos in forum Capturing and VCRReplies: 3Last Post: 25th May 2008, 20:52 -
ADS Technologies Instant DVD 2.0 Driver Download
By alexsum in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 21:58 -
Using "ADS Instant DVD For Mac" to watch live TV
By donaldxdog in forum MacReplies: 1Last Post: 11th Dec 2007, 16:24
