i tried clonedvd and i like the program, just one thing though. Say it says the compression will be 90%, but after removing audio streams there should be room so it can go higher yet the compression bar wont show it. my question is even though the bar doesnt show it, will the compression still be at 90% or does it actually compress it a lil less to since there is room for it?
thx
it compresses it a little less. this can be verified by the final output file size
Clonedvd 2 question...
By ironmanDD in forum DVD RippingReplies: 1Last Post: 20th Jan 2011, 23:41 -
CloneDVD Feature Question
By jeanpave in forum DVD RippingReplies: 4Last Post: 7th May 2010, 03:26 -
Do i have to get clonedvd?
By blaqlion22 in forum DVD RippingReplies: 3Last Post: 30th Jan 2008, 10:28 -
CloneDVD 2 crashes at startup
By pacopaco in forum DVD RippingReplies: 3Last Post: 24th Jan 2008, 14:28 -
CloneDVD or Shrink?? Which is Better?
By Jonathan in forum DVD RippingReplies: 15Last Post: 22nd Dec 2007, 20:52
