Hi,
When I play a DVD I created in Adobe Encore on my DVD player, some of the videos appear very choppy, but when I play the DVD on my computer, the videos appear to be fine.
Any ideas?
Thanks for the help.
Hi,
I just tried the dvd in my player again and it worked fine. Not sure what happened the first time.
What do you guys think happened?
Thanks. -
Someone else just posted regarding this problem. Look back a few days to see what was said. I think it's just incompatability with the standalone player and your method of burning. Someone else mentioned it could have to do with interlacing. What method are you using to burn? I create the image in Encore and burn with DVD Decrypter, or occasionally make folders with Encore and burn with Nero 5.5.
I just burn the disc using Adobe Encore (File, Build DVD, Make DVD disc...). Do you think this method is not reliable? Should I use another program to burn instead?
Thanks. -
I personnally burn with Nero in the DVD Video mode. This has worked with all DVD players I have tried it with.
OK, I tried saving the image of the dvd in Encore to burn later, but it won't let me make a file size more than 4 gigs.
Anyway to get around this?
Thanks. -
NTFS file system I think... or use DVD Folders instead of DVD Image. You can always burn DVD folders with Nero's DVD-Video option and it works great with stand-alone players.
Arek
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 01:09 -
Subtitle in Adobe Encore 2
By bebado22 in forum Authoring (DVD)Replies: 0Last Post: 30th Sep 2010, 14:45 -
Problem importing Russian subtitles into Adobe Encore
By adanepst1 in forum SubtitleReplies: 2Last Post: 29th Jan 2009, 13:12 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 00:09 -
Adobe Encore Help
By Entengdigital in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2008, 02:36
