I am trying to burn off a DVD that is on my H/D using Nero 6.0. but keep getting File Reallocation error and a failed Burn Is their something i can do to rectify this ???????![]()
Download the Latest Nero Updates and try it again see if it's fixed.
My advice would be to use UDF/ISO mode; as long as you keep the dvd similar to dvd-video standards (include a VIDEO_TS and AUDIO_TS*) folder and don't relax restrictions there shouldn't be a problem.
*Yes, I'm aware that in most cases an AUDIO_TS folder isn't necessary, but I've heard of problems that can occur when it isn't present, so it's good to have one, even if it's empty. -
Read one of the fine guides available here on this site .
Keep it on the big cam ! -
Thanks to all that replied !
Have Ugraded Nero to v6.3.0.2 and it let me past the dvd video compliance test and burnt to a DVD-R. Got to play on my PC and My Cyberhome Standalone dvd player . However for some reason the Subtitles wont turn off from the films root menu ?
I can turn off from the Remote control but it only turns off for the chapter that is playing and subtitles reurn at the next chapter !#
Is there a way of removing the subtiltles from the original files so that i can re-burn without ?
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Problem with burning DVDs on Power2g, "not a valid file" error, please help
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 7th May 2010, 20:19 -
Error encountered on burning file unto dl DVD
By jones24 in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2009, 00:22 -
DVD-video files reallocation failed
By Sean_ve99 in forum DVD RippingReplies: 3Last Post: 23rd May 2007, 19:44
