i've used ulead movie factory a few times to make my dvd movies, i've usually got the mpeg2 movie which i re-encode to mpeg1 so i can fit a couple of films on a dvd-r disc, however i have some avi files which are smaller than mpeg1 but they dont seem to burn, it just keeps saying no room on the dvd-r disc, it only uses 3.2gb of the 4.3gb, i dont understand, is it just not compatable with AVI?
I tried again last night, a brand new disc, and still the same messgae asking me to insert another disc as there is no room on the one burning.![]()
Please...anyone....help?
Not sure I followed you going from mpg2 to mpg1 to avi but:
Within MF-2 you need to set the project setting to something that will fit on the meadia and check the box "do not re-encode compliant dvd" IMHO
Ithink this is the setting MF-2 uses to pre-verify ouput will fit
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 09:42 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 04:48 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 14:12 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20 -
Ulead DVD Movie Factory
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14
