Hi,
I hope I have the right forum. I use DVD shrink to rip my dvd files and wanted to use DVD Decriptor to do the burning. I am using a Plextor 708a and had previously used a trial copy of Nero with good success.
When using DVD Decriptor I cannot seem to load the already ripped "Video_TS" file to be burned. It askes near the top of the window TO "Please select a file". I click on it and fild the "Video_TS" file but don't seem to be able to open or load it to be burned.
Is there a help file for this program as I have not been able to locate one.
Thanks for any help
Tom
Cape Cod
OK wait a sec, are you guys serious, or are you just not using the correct terminology?
As far as I know, DVD Decrypter does not burn. At all. It only decrypts the dvds and takes off the copy protection and/or makes it region free. You need nero or another burning program to actually write the files to dvd. -
Originally Posted by bigcookie_88
How to burn a DVD-Video using ImgTool, DVD_Decrypter
http://www.polarhome.com:793/~afonic/imgtool.htm -
IMGTool can do the burning but it can also just make an ISO and you can burn the ISO in Decryptor. Mode Menu>ISO>Write
DVDDecrypter DOES burn in ISO mode. It also burns images created in IFOEdit with the same ISO Write application.
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 7Last Post: 7th Aug 2016, 12:31 -
Load AVCHD Lite mts files into VirtualDub?
By MJ Peg in forum Video ConversionReplies: 18Last Post: 1st Aug 2012, 12:28 -
Handbrake unable to scan/load source video files.
By e6bwhiz in forum Video ConversionReplies: 1Last Post: 22nd Feb 2011, 16:44 -
Files slow to load in MPC
By MattG in forum Software PlayingReplies: 6Last Post: 15th Sep 2009, 03:29 -
Here is a test: Storage of a S**t load of HD video files
By Lesley NZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 25th Apr 2009, 12:26
