The old Premiere would allow you to type in a specific time and allow you’re to capture that limit. With Pro I don’t see that option? What capture software would you recommend so I can type in a capture time and leave the room?
Thanks,
Jim
You can definetely still do it with PP.
Choose File>Capture
Click the logging tab and you will see in the lower right portion of the pop-up window all your settings for selecting time codes. -
I think that only works if the tape has time code. I want to use an analog source and capture with a Canopus ADVC-100. I don't own one yet. Does the Canopus generate time code if I play it though it?
Jim -
No idea about the capture card but if you were able to do it with P6.5 you will be able to do it likewise with PP.
Windows Movie Maker capture import to Premiere Pro
By burrenyoga in forum Capturing and VCRReplies: 5Last Post: 24th Aug 2010, 09:36 -
AVCHD or HDV Capture in Premiere Pro CS4?
By AjSVB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 2nd May 2010, 13:08 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 14:59 -
HD Capture questions w/ Premiere pro
By miamibluemoon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 27th Feb 2008, 01:38 -
SVHS Capture / Premiere Pro 2
By tokyomaskproductions in forum Capturing and VCRReplies: 4Last Post: 16th May 2007, 13:48
