I use a SONY Digital8 camcorder to record NTSC video off my DirecTV TIVO system. I capture and edit the material in Adobe Premiere. I than use TMPGEnc to encode the material to DVD format.
It seems that whether I use field order A or B, I get what look like interlacing effects. I than tried IVTC which seemed to take care of the problem. I than imported the IVTC MPEG-2 in DVD-Lab, only to be prompted that it needed 2:3 pulldown. I than re-encoded the material in TMPGEnc with IVTC selected (this defaults the frame rate field to 23.976)and selected 3:2 pulldown when playback (this added the information "internally 29.97fps" to the frame rate field description. The result is accepted in DVD-Lab.
Is this an OK way to go? Is IVTC really the right way to go if I'm not sure the material was FILM to begin with? Why did IVTC seem to take care of the problem? What does the 3:2 pulldown really do?
Not usre why you would need IVTC unless its as a result of something the TIVO does, perhaps it always stores material at 23.976fps with 3:2 pulldown to reduce file size (less frames means it needs less bitrate). Dunno, just guessing at that.
So when you capture it with your DV cam, it is effectivley telecined back to 29.97fps.
But adding 3:2 pulldown flags to 23.976fps material is mandatory for NTSC DVD. The flags just tell the player to repeat certain fields in the source material in a 3:2 pattern such that the final framerate will be 29.976fps.
TMPGEnc: 720P -> Progressive or 3:2 Pulldown?
By akrako1 in forum Video ConversionReplies: 6Last Post: 13th May 2008, 12:51 -
help with dvd re-creation
By souleye in forum Authoring (DVD)Replies: 0Last Post: 21st Jan 2008, 19:12 -
DVD creation..
By Fathead31 in forum Newbie / General discussionsReplies: 7Last Post: 5th Dec 2007, 23:46 -
Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
By Hal05154 in forum Newbie / General discussionsReplies: 9Last Post: 25th Sep 2007, 13:13 -
Advanced DVD menu creation in TMPGEnc DVD Author 2.0
By roma_turok in forum User guidesReplies: 45Last Post: 23rd Jul 2007, 11:11
