Hi i have no problem when i convert SVCD to DVD but when i use VCD they only play on certain players any ideas? maybe i need a different bit of software?
MicaerinGuest
The problem isn't the software it is a VCD.
Putting VCD on a DVD is a very long process and i know cause i've been trying to find a fail proof way for 1,5 years now. And i can tell you i think there isn't. VCD have the tendency to run out of sync when you burn then to DVD-VCD or at least 90% if you use them without any preperation (reencode the audio with tmpgenc to normal VCD audio, see the sticky topic about audio/video sync). And afterwards 20-25% still give troubles, sometimes it helps to reencoded the whole VCD to VCD again but sometime the only thing that helps is make a completely new VCD form scratch.
The bottom line is this: Burn VCD on DVD is a time consuming and irritating process.Greatings,
Yf
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
