The docs sez to use vidtoasf.exe, wich is "available" from Micro$oft. I have not been able to get this util in any of the distrubutions o their site. I basically want to convert two .avi (MPG43) into some format that I can then join and put onto a vcd.
Any suggestions?
why would you WANT an ASF file? they are about the shittest form of video that is possible. ASF SUX
What other format than asf to you recommend. I have the two .avi's wich I want to join using VirtualBlubber(I think that is the name) but it cant open the .avi's because of the MP43 codec, wich I can't find. Now I first need to convert these two avi's into something else, so that I can join them, and then put them onto a vcd.
Converting ASF and AVI to AVI
By Tatl in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2010, 16:18 -
ASF to AVI
By Arizona42 in forum Video ConversionReplies: 1Last Post: 31st Aug 2008, 23:20 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 08:40 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
AVI to asf ?
By rindless in forum Portable VideoReplies: 38Last Post: 26th Jun 2007, 09:15
