  1. Anonymous
    Guest
    hi
    I am using SVCD2DVDMPG v1.1.1.16608
    trying to convert some VCDs .bin files and it always gets to step3
    were it says 'Resampling audio from 44.1KHz to 48KHz'
    and like it stops there - left the pc on over night and no progress
    would appreciate some reply back, thanks
  2. Could you post the log file here? and the technical information about your VCD?
    We need some more information to help you.
    Greatings,
    Yf
  3. Anonymous
    Guest
    hi,
    thanks for the reply
    its actually any VCD I try
    but here is the log of one of them:
    Starting (S)VCD2DVDMPG: v1.1.1.16608
    Begin time: 10:39:37
    ******** Ripping SVCD images (step 1 of 3)
    --- File details:
    D:\obs-mra_01.mpg
    Mpeg 1 System File [Video/Audio]
    Muxrate : 1.39 Mbps
    Estimated Duration: 01:08:41.06s
    Size [352 x 240] 29.97 fps 1.15 Mbps
    Audio : Mpeg 1 layer 2
    224 kbps 44100 Hz
    Stereo, No emphasis
    --- File details:
    D:\obs-mrb_01.mpg
    Muxrate : 1.39 Mbps
    Estimated Duration: 01:08:40.74s
    224 kbps 44100 Hz
    Stereo, No emphasis
    ******** Demultipexing original mpg files (step 2 of 3)
    ******** Resampling audio from 44.1 KHz to 48 KHz (step 3 of 3)
    that was done this morning and its still stuck there
  4. Anonymous
    Guest
    hi
    I just tried a SVCD .bin file and it does that fine
    so it cant do VCD format?
  5. It can do it fine i've done about 100 or so now. but i do VCD mpeg files not bins. You might try ripping the mpg of the VCD yourself with VCDGear or Isobuster..
    Greatings,
    Yf
  6. Anonymous
    Guest
    ok I tried VCDGear to get the .mpgs but still it gets to that maplay.exe part and just stops there :/
    like it cant seem to convert the .mp2 to .mpa audio format
    what else can I do here ?
  7. Do it the hard way:
    1. demultiplex the .mpg file with tmpgenc
    2. encode the .mpa audio with besweet to .mp2 with 48 khz sound. Best way to do this is mpa -> wav, wav 44.1 -> wav 48, wav 48 -> mp2
    3. multiplex the .mpg file with tmpgenc
    4. run it through svcd2dvd again.
    If you do this steps it doesn't have to reencode the audio..
    Greatings,
    Yf
