  1. i just recently purchased my dvd burner and before i got it i was using dvd decrypter in ifo mode to make rips. i still have some of these burn when i try to burn them i get errors. is there a way to burn these (movie only) files to a dvd?
    thanks for any help
  2. Have you tried opening Nero express, chosing DVD-VIDEO and then open up the VIDEO_TS folder in the wizard, and drag and drop all the files from a dvd that you want to burn. Follow instructions, and burn.
    If you've done that, try ripping with a different program.
  3. you don't have the primary BUP and IFO files. Delete your BUP and IFO files. open IFO Edit. click the create new IFOs button at the bottom. select the first VOB file in the set, it'll get the rest automatically. select the same as source box. start it and let it generate new IFO and BUP files for you. then you should be able to burn.
  4. Originally Posted by Poppa_Meth
    awesome it worked
    thanks for your help!
