i used search and i read da articles so dunt flame me plz.
i cant find the files Cdudf_xp.sys or Udfreadr_xp.sys. i tried the path HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\. nothing.
although i did find a file named meiudf.sys. should i delete taht? im not sure where its from haha. i jus got this LG-4040b. i tried reinstalling the ram driver and nero and da bundle software that comes wif it. does cd clone affect it? i dunt fink it should. or wat bout winDVD? i dunno. da b's clip jus dunt recognize da disc.
Exactly what difficulty are you having? Are you saying that B's CLiP program doesn't recognize DVD-RAM? Frankly, I don't think it should.
After installing the DVD-RAM driver, Windows XP itself should automatically recognize a DVD-RAM as a removable disk drive. You should be able to read and write to it using the ordinary WinXP operations, roughly as if the DVD-RAM were an enormous floppy. Are you saying that you cannot do this successfully? What is happening instead? Frankly, if you have CLiP installed, it might actually be the problem!
Are you able to read the DVD-RAM but not write to it? Does WinXP falsely claim that the DVD-RAM is write-protected? -
yea it saids its write protected. b clip wont format it because it doesnt recognize it as a valid disc. i have formatted the dvd ram with xp's original formatter and the dvd ram driver that came with it. both do not work and give me the same error
What you're describing does sound similar to what happened to me on one of my computers. In my case, as you may have read, the culprit was DirectCD, the packet-writing portion of Easy CD Creator. That's why I had to disable or delete the two .sys files you mentioned.
I can only suspect that perhaps you are seeing an equivalent conflict from CLiP, which is B's packet-writing software. In that case, you might have to (a) uninstall CLiP, and perhaps (b) disable or delete any UDF reader files it has left behind. But I'm just guessing. -
yea i did read ur post. i guess i'll try uninstallin b's clip now. ohh and no i have trouble formatting the DVD ram with xp and da driver. it saids da disc cannot be written on. imma try da software bundle dat came wif it. wish me luk
Man, I don't want to cramp your style, but try to type in a real language when your trying to get technical help. If we cant understand the yabb dabba doo lingo its kind of hard to tell whats going on.
So did you disable windows XP capability to write CDs on the drive, because XP cant use DVD-RAM if that setting is turned on.
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
DVD Recorder does not recognize anything above Channel 36
By Marianne777 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Jan 2010, 16:11 -
Nero can't recognize CD/DVD Recorders!
By Charmer in forum DVD & Blu-ray WritersReplies: 16Last Post: 15th Nov 2009, 05:54 -
Toshiba DR2 Won't recognize DVD-RAM any more
By jpc82 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Dec 2007, 10:31 -
Toshiba Satellite Vista laptop won't recognize ram upgrade
By edong in forum ComputerReplies: 17Last Post: 25th Jul 2007, 22:49
