Can anyone tell me the difference between the G03 and G04
From the looks of it the 03 is 2x and and 04 is 4x
Anyone had any problems with the G03 - they are quiet a bit cheaper than the G04
I've been having major problems with Verbatims and from all the posts Ive read Riteks look like a good option. Should I use the 03 or 04's though?
Results 1 to 13 of 13
Either one is an excellent choice as long as you get grade A quality Riteks.
Not sure what the difference is, try looking in the DVD Media guide on the left
I'd definately try Ritek's though, I'd use Mirror Platinums in the past, and constantly got the dreaded stuttering/pausing/lock-ups when past the half-way point on the DVD and especially when it was getting close to the edge of the media
Recently got the chance to try out the Ritek's ink jet printables I bought from the local computer supplier I use, who's managed to get one of his suppliers to get Ritek's for a good price
Burnt DVD's so far, both with 2 movies, and the 2nd DVD had the movies running very, very close to the capacity of the media, not delibrate, but it proved it was the media at fault not the player
Not a single glitch/stutter, nothing
Well worth the extra outlay -
Thanks - will def try and get some. The problem is finding a good place that does international shipping.
Not sure where you are based, but I am in the UK and can recommend these two suppliers :
http://www.ketta.com/catalog/default.php?language=en
http://www.blankdiscshop.co.uk/acatalog/copy_of_FOR_DVD_R_RW_CLICK_HERE.html
Hope this helps----Figured it out yet?
----What's that?
----Who's the best pilot!
TOP GUN (1986) -
I'm consistantly getting G04's for around $1.00 US delivered. The G03's would have to be significantly cheaper to get me to buy them.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Pray tell where are you getting the G04's for that price, delivered?Originally Posted by Gazorgan
Hurry, tell us before this thread (maybe) gets yanked into a different forum.
Uber -
Try here my last 100 were for 105.00 delivered.
http://www.supermediastore.com/ritek-4xdvdr-fs.html -
Thanks for the info. I've ordered from them before. Unfortunately, I need +Rs. Plus, since I'm in CA I get dinged with tax, too.Originally Posted by Bodyslide
Now if only I could get +Rs for ~$100 delivered...sigh.
Uber -
Sorry, $100 US.
Newegg.com (free shipping) has them. Supermedia has them also, with a $5 discount.
As far as canada goes, the exchange rate makes them what, $140 CA? It's the VAT and provincial tax that kills you. We should meet at the border, I'll give you RITEK's and you give me Cuban cigars? Make sure neither of us any meat sticks :PTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
Ha! Should've been more, uh, clear. I'm in California. I haven't looked at Newegg.com, but I have never seen the RITEK 4x +Rs that low at Supermedia. Are you talking x2 discs?Originally Posted by Gazorgan
Just looked at Newegg and I only found 2.4x discs.
Uber -
dvd-r 4x discs @ rima.com are $95 for 100 pack... ritek g04's ....
i dont know about the + though
Thanks vettesea, I'll try out those. I'm in South Africa and most places do not do international shipping - let alone to S.Africa
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 19:14 -
Sony +R Differences
By Madz in forum MediaReplies: 4Last Post: 31st Dec 2011, 03:46 -
Differences between these two files..
By dhr in forum Software PlayingReplies: 4Last Post: 13th Feb 2011, 21:35 -
Player Differences
By Xandal in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 15:43 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
