Hi,
Just wondering if this is normal. Took about 1.5 hours to burn a DVD+RW at 4X speed. This includes all the processes it goes through except the DV Video capture. This was a video that was 102 minutes at the DV-AVI type 2 method. I am using the ULEAD Video studio 7 software. ( Can't wait until 8x discs come out !!!)
Also , would anyone know the diference between DV type 1 and 2? Is one better than other? Thanks in advance.
I suspect that what your time represents is the time it took ULEAD to process the DV AVI (convert it into MPEG-2), author a DVD and burn. All that for 1.5 hours is just fine.
Additionally, burning a DVD+RW at 4x is only possible with 8X burners. All 4x +R burners I know can only burn +RW at 2.4X, which translates into 20 min or so.The more I learn, the more I come to realize how little it is I know. -
Ricoh5240, LiteOn 401,411, BenQ400, Sony510Originally Posted by SaSi
These are 4xDVD+R, 4xDVD+RW burners -
Just burning a DVD+R/RW at 4x should be ~14 minutes and 2.4x should be ~24min.
If it's taking longer than that, then the software is doing something else(like Sasi said) or maybe it shows that it can burn the media at 4x, but there might be something going on on your machine that is preventing it(non-DMA mode or something). -
Hi,
When I said it takes 1.5 hours, that time included the other operations that go on including the burn time. Thanks for inputs.
Author/burn software which burns many mpgs in < time than Win DVD Maker
By wetcamelfood in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2011, 12:09 -
burn 2 dvds at the same time.
By dymx in forum DVD & Blu-ray WritersReplies: 8Last Post: 12th Dec 2008, 17:58 -
Burn 3 DVDs at a time
By Dimava in forum DVD & Blu-ray WritersReplies: 42Last Post: 5th Aug 2008, 16:31 -
**Help! Need to burn a DVD and running out of time to do it!**
By catdrummond in forum Newbie / General discussionsReplies: 1Last Post: 19th Oct 2007, 08:53 -
By catdrummond in forum DVD RippingReplies: 1Last Post: 19th Oct 2007, 08:51
