I've been having a problem with just about every software DVD player I've
used.. when the DVD changes to the 2nd layer the program freezes up for
5+mins and continues about that much farther into the movie. I've used
PowerDVD, windows media player, VideoLAN, and the ATI dvd player+decoder
that came with my video card. I decided to try winDVD plat. 5 trail and it
still jerks for a split second on the layer change but thats totally
acceptable, however I don't feel like spending $70 for it.
I'm using Windows XP w/sp1 and ASPI 4.71, Radeon 9800pro with v3.10 of the
drivers, and the dvd player is a DR-Tech 16x IDE.
If someone can help with this problem I'd appreciate it a lot.. otherwise I
guess I'll be heading to bestbuy soon![]()
Results 1 to 1 of 1
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
