I'm having some problems with Verbatims 4x -R (The MCC ones)
I've tried Nero and RecordNow (latest versions) on my NEC-1300A (with latest firmware) and on reading back my dvd it give errors about 98% of the way. If I keep the image to < 4GB all seems ok.
Are the errors due to bad media? If its due to bad media, is there something I can run on the blank media to check it before I burn it. Seems a bit of a waste burning it to find out of its bad.
Any advice would be appreciated.
Try using a dvd rewriteable disc first. If it burns and plays fine then it could be the Verbatim's disc. Check Herrie's site for some tips.
http://www.herrie.org/
You can also check this site:
http://forum.firmware-flash.com/viewforum.php?f=2
Good luck!
I've tried rewritables - works fine. On the verbatims about 3 out of every 10 burn with no problems.
Thanks - I live at the herrie site
My feeling is that its the verbatims....and I thought it was a decent brand
I've had the same problems with the same media. Verbatim isn't what it use to be. I'm much happier with my Riteks.
Best choice for blank DVD media since Verbatims are hard to find
By alvabass in forum MediaReplies: 7Last Post: 29th Apr 2012, 00:58 -
Bojack Verbatims at TigerDirect?
By rumplestiltskin in forum MediaReplies: 7Last Post: 14th Feb 2010, 05:16 -
Wah! Bad Verbatims (+R)
By BetaMaster in forum MediaReplies: 55Last Post: 12th Oct 2008, 16:47 -
ImageSource giving errors when reading Photoshop .bmp files
By DVD_JS in forum EditingReplies: 0Last Post: 20th May 2008, 19:21 -
unreadable burns with Verbatims and Liteon SATA DVD drive
By eternity3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Dec 2007, 04:10
