Hello I've used DVD Shrink and everything works great except there is no sound now. Was I wrong in keeping DTS-6ch English only? Also compressed the video to 20% if that has anything to do with it.
If I need to remove the DTS-6ch English, what do I need to replace it with? The ones that are there are: AC3-6ch English,
AC3-2ch English and ACT-2ch English (why there twice?)
Also is there some way I can just replace it without having to Re-author/back up again?
Using Shrink 2.3.. had problems with 3 beta
Some standalone players are stuborn on the DVD-Video spec that dictates the presence of LPCM or AC3 for NTSC and LPCM,MP2 or AC3 for PAL respectively.
AC3-6CH is probably the one to keep. AC3-2CHs are often for director's comments -
Ok thanks heaps for that. Its a shame you can't preview the sound with DVD shrink.
ahhh ok.. is there a program I can use to replace the sound and also preview it? With license from Dolby-lab? Trial program or something?
OOPS ! Formatted my Mac HDD back to NTFS (had files) !
By NotSoEasy in forum ComputerReplies: 3Last Post: 6th Apr 2012, 01:31 -
Oops, converted home video file is massive, how to fix?
By grathan in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2012, 11:26 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
oops, I've stumbled into the wrong forum
By MackemX in forum Off topicReplies: 8Last Post: 1st Nov 2007, 16:27
