any recommendation will be appreciated, i need a good free dv capture application using firewire that works on win 98....thanks much.![]()
DVIO works under Windows 98 (and SE) and up.
I use it all the time w/ my advc. However, there is a FAT32/4gig/18min limit under non-NTFS setup (W2K/XP only have this feature)
I'd like to find a DV app that will "segment" my caps. Freeware that is.
No shareware. I read elsewhere's that you can get vdub to work w/ DV
to capture (transfer via firewire) but I think that it was just a hokes (IMO)
since I tried to no avail.. so don't be fooled that vdub works w/ DV - - it doesn't !!
There is seanalizer (spelling) that can do "segment" (I've used it) but it's
also shareware, and has limits as well as a logo. So, this is not good either.
DVapp doesn't work under Windows 98. I've tried this also, under my gold
version. I think it might work under ME and up though.
I can't think of any other DV app for plain old Windows 98
For now, I continue to use DVIO and just live w/ the 4gig/18min limits
until I find another freeware app that incorporates some form of "segment"
capping ability - - vdub was my last hope.
Good luck,
-vhelp -
hi jakol,
your DV issue could be any number of items amiss. I know. I have 2 pc's
that I use mostly for capturing and encoding and things like that.
On one of my pc's, only my Canon ZR-10 will work via fiewire (FW) but that's
it for DV devices.
on another pc, everything works
In my case, its a matter of FW card I have in my system. These two pc's
I was dicussing are both equip w/ same mobo..
* ESC K7S5A / XP 1700+ and 1800+ w/ Windows 98 (gold) on both.
In my 2nd pc (working FW one) it's using the card by Pyro. My other pc I
believe, has the one from Pinnacle DV Studio or something like that.
The Pyro card words great though, w/ DVIO.
Under Windows 98 (Gold) (not SE) you have to find a driver (unless your
software app installed one for you) In your case, I think your SW did install
such a driver. So, I think it's just a matter of finding out which FW card you
have in your given pc.
-vhelp -
my comp comes with the firewire driver/ and software for dv transfer... dvgate motion. If i use DVgate motion though i can control my cam with its device controler (play ,stop etc.) but its not caturing/transfering data...i emailed sony support and will just wait for now...neway thanks for the info.
Lnux video capture apps ... suggestions?
By Nitemare in forum LinuxReplies: 14Last Post: 9th May 2013, 22:35 -
Intensity Pro Gradually Desyncs in capture apps, please help!
By swiftor in forum Capturing and VCRReplies: 5Last Post: 30th Aug 2010, 20:50 -
JVC GR-DVM828 Not showing up in any capture apps
By jammery2k in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th May 2008, 12:03 -
What free Apps for screen capture other than CamStudio
By Firewire60 in forum Software PlayingReplies: 0Last Post: 21st Feb 2008, 18:29 -
Need Apps to capture sound from cassete tapes to PC and convert to MP3
By Firewire60 in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2007, 20:30
