I can't decide on which burning software to buy. I am thinking about buying Nero 6 but i've heard that nero has problems with 4x drives, which i have (lite-on 411s). I also am thinking about getting Pinnacle Instant Copy, but I heard it was slow.
Please post the software you use and list the advantages it has over others.
Alot of members here seem to like RecordNow Max.
SLICK RICK
Originally Posted by lordsmurf -
Best is subjective.
I've been using Nero since version 5.0 and have never had a problem with it.
Most come with free trials, so I would go out and download a bunch, test them out and see which ones work and have the features you like. -
I also use Nero but have read alot of posts from people that have had problems burning with Nero, I have not had any problems so I will continue to use it until I do.
SLICK RICKOriginally Posted by lordsmurf -
Hi,
I'd go for Nero 6 as the main dish, accompanied by a side order of freeware - either BurnAtOnce or Deep Burner.
My only problems these days with burning dvd's are from the quality of the blanks, never with Nero nor BurnAtOnce. I have tried Record Now Max, but I could get used to it.
B1. -
I've been using Nero since version 4.? for CD's then started looking for a DVD Writer and came across this site. I read all the bad things about nero and was sure I was going to have to give up my favorite software to burn DVD's. I got my new Pioneer A06 installed fired up nero 6 and burned my very first perfect DVD after using DVDDecrypter and Shrink. I have since burned about twenty perfect copies using Nero and will also continue using it. 8)
Rick
burning software
By hardy in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 19:00 -
Best Burning Software
By bmoreravyns in forum Authoring (DVD)Replies: 32Last Post: 14th Oct 2008, 21:46 -
Best burning software???
By Eternal7331 in forum DVD RippingReplies: 8Last Post: 11th Oct 2007, 01:29 -
what burning software?
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Oct 2007, 18:48 -
burning software
By Cmonteith in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 20:07
