I'm a newbie and I don't understand firmware all that much. All I know is that it is basically a driver for your cd or dvd drive. I've heard that there is a bad firmware update for my Lite-On 411s and was wondering which update it is and if I should download it. If I shouldn't download it, how should I update it?
You should go to the Lite-On website and update to FSOF if this isn't what you have.The "buggy" firmware was FSOG and they removed it from the Lite-On site.
I hope this doesn't upset anybody ... but here goes ...
Link >>> http://club.cdfreaks.com/showthread.php?s=77364b11f69b27920bc953e6a45ef8b4&threadid=82...highlight=FSOG
Club CD Freaks - Knowledge is Power > International Chat: Hardware related > Recording Hardware Forum > LiteOn Forum > Lite-On removed FSOG for 411s from their site
Last Thread Next Thread
Author Thread
sardian
New on Forum
http://www.liteonit.com/ODD/english/index-english.htm
Looking at the above link, Lite-On must have found the bugs, reported on the forum, with the new FSOG firmware for the 411s. It is no longer available.
I have been drooling over the new bitsetting tool (I have a 451s) but it seems that it only works with the 411s/811s and the newest (removed) firmware. I would think twice about updating for a while to use this new tool.
29-12-2003 04:19 IP: Logged
d2ba
New on Forum
I think FS0G may have been removed not because of bugs but more because of security holes ie Bit setting now works with FS0G.
In short FS0G may make the 411S too hackable?
29-12-2003 04:37 IP: Logged
wesociety
New on Forum
OCFreak, any news from your Liteon tech contact on why FSOG was removed?
__________________
http://www.giogiscafe.com
http://www.geocities.com/wesociety
29-12-2003 04:41 IP: Logged
sardian
New on Forum
There has been a problem reported when recording DVD+RW at 2.4x.
Also, here is the correct link that takes you streight to the Lite-On firmware page.
http://www.liteonit.com/ODD/english...ad-firmware.htm
29-12-2003 04:43 IP: Logged
rdgrimes
Moderator
The firmware was likely removed because we reported the bug with 2.4x RW burns. They'll replace it in a couple days when they find the bug. Everything is not a conspiracy.
__________________
For media FAQ's, check HERE
For a searchable database of DVDR/RW media tests, check HERE
For a searchable database of CDR/RW media tests, check HERE
Interpreting C1/C2 errors (CDR/RW) HERE
Interpreting PI/PO errors (DVDR/RW) HERE
And don't forget to try the SEARCH button!
Current drives running here: LDW-411S, DVR-106D, LTR-52327S, XJ-HD166S.
29-12-2003 04:59 IP: Logged
jsl_blues
New on Forum
Looks like they yanked other new FW versions just released during Christmas; HS0J for the 811S is gone, too.
29-12-2003 05:14 IP: Logged
beefy99a
New on Forum
Yeah they did. I wonder if they are going to fix other problems with the firmware, like dvd-r's not finishing the finalize process. It gets to the finalize then the red light stays on forever so i have to reboot to get it to stop burning. The i checked the disk and it started writing over the data it allready wrote. i switched back to fsof. Since some people here are close with lite on, put in a word for me. Thankyou
29-12-2003 05:30 IP: Logged
Dartman
CD Freaks Rookie
I've had problems doing a dvd+rw format also and my Ritek GO4's have worse error rates with it so I went back to HSOE and they burn great again.
Hopefully they fix the rewrite problem and tweak the write stratagy so it keeps the good parts of the older firmware and still includes better support for the new media they added.
29-12-2003 05:39 IP: Logged
d2ba
New on Forum
FSOG works fine for me and Im a newbie to the DVD recording
--used -Rs no problems
29-12-2003 07:48 IP: Logged
FOAD
New on Forum
It's possible to remove 0G and reinstall 0F???
29-12-2003 08:09 IP: Logged
FOAD
New on Forum
ok i search and found my answer
29-12-2003 08:39 IP: Logged
phildts
New on Forum
quote:
to Beefy:
I have the same problem. After I flash my 411s to FSOG, it begins
unable to finalize DVD-R. I don't have such problem with FS0F.
The disk wrote with FS0G became unreadable after reboot.
Hope they can solve this problem soon.
29-12-2003 10:22 IP: Logged
OC-Freak
Senior Admin
My contacts have informed me that they removed it because of the serious DVD+RW writing bug| in HS0J and FS0G.
I don't think anyone needs to worry about the bitsetting support as Lite-On is also working on this for some OEM customers (and thus some commands is implemented in the latest firmware)....that is why someone was able to write the bitsetting tool in the first place.
__________________
Please read our rules and use our search function before you ask any questions, and please provide enough information(Computer, OS, programs and drivers installed and such).
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
-Mark Twain
You may not see me often yet, as my Internet Connection is near non-excisting........ But I'm onto reviewing some drives soon so stay tuned.
29-12-2003 11:33 IP: Logged
nemesis101
New on Forum
so how soon is the new firmware going to be out??
have they mentioned it to us......or does anybody know??
by the way does anybody here know where i can get the FSOF.bin file, i cant revert back to fsof at windows after i flashed to fsog
__________________
AMD me
29-12-2003 11:41 IP: Logged
pinto2
CD Freaks Member
quote:
Originally posted by nemesis101
...by the way does anybody here know where i can get the FSOF.bin file, i cant revert back to fsof at windows after i flashed to fsog
You can use:
http://club.cdfreaks.com/showthread...7850#post507850 (flashfix) with FW from:
http://www.liteonit.com/ODD/english...ad-firmware.htm or...
http://dhc014.rpc1.org/indexOEM.htm
Still wana FS0F-binary? PM your email.
__________________
Asus CUSL2-C [I-815PE] \ Intel P-III 733MHz \ 384 Mb SDRAM \ Asus GF4-Ti4600 \ WD 80Gb /8Mb/HDD (0:0) \ Memorex 40Max (0:1) \ Lite-On LDW-411S (1:0) \ Pioneer DVD-106 (1:1) WinXP Pro SP1
29-12-2003 12:12 IP: Logged
Macrovision Firmware Lite-on LVW-5006
By drewbert73 in forum DVD & Blu-ray RecordersReplies: 36Last Post: 9th Sep 2012, 12:05 -
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 04:45 -
Want to use K-Lite? - DON'T DO IT!
By jeanpave in forum Software PlayingReplies: 45Last Post: 15th Nov 2010, 23:04 -
New Lite-on drive being recognized as old lite-on drive
By tlrbjc in forum DVD & Blu-ray WritersReplies: 2Last Post: 23rd Jun 2010, 09:21 -
nintendo ds lite
By Mr anderson in forum Off topicReplies: 5Last Post: 19th Sep 2007, 02:02
