According to my previous questions about svcd and tmpgenc bitrate.I was told to make small test clips at different bitrates.If I understand correctly different dvd settop players may play a svcd different from one to another.I understand that as far as my dvd player goes I can get the svcd to look as good as it will played on it.How do you go about making a svcd for a customer and not being sure it will look good on there player?Is there a sure fire encoder out there that will look good at the same bitrate on all players?Does anyone out there do the svcd format in the buisness sense and what do they use?
thanks rikit
Just my opinion, but SVCD is not a great format for business use. A lot of DVD players can't handle it. But if your bitrate is within the SVCD specs, it should look the same on most any SVCD compatible player. Other SVCD functions, such as fast forwarding, zoom, chapters, etc., can be problems with different players. If you are looking for higher compatibility with CD video, VCD format is better, but a lesser video quality.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 08:09 -
HC Encoder....help
By Creed in forum Video ConversionReplies: 3Last Post: 3rd Apr 2011, 20:12 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41
