Hi, I'm using Clonedvd & Any DVD on a WinXP 1.8 P4 with 256 megs of ram. From start to finish, burning at 4 speed, each disc has taken roughly
2 hours to back-up. Is this a good speed? I wondered if adding more memory would help and if it does is there a program that tells you exactly what type of memory is in your PC as it's not listed in the manual. Thanks.
I hate to tell you, but you aren't burning at 4x. Typically, burning a DVD at 4x (without any compression) should only take about 15 minutes. Check to see if your drives are in PIO mode or using DMA. I had a problem with slow burns (100+ minutes) once, the problem ended up being a bad IDE cable.
Yes, I mean transcoding and then burning, although burning for e.g Catch
Me if You Can took 63 minutes. I have DMA enabled but have no idea what it does or means. Is PIO better? Thanks. -
A 4x burner should burn a full image in roughly 15 minutes.
'Ripping' (or reading your source) will take anywhere from 5 minutes to over 1 hour (2x DVDRW drive reading a full DVD9).
That gives you 20 minutes to 75 minutes without any transcoding. Transcoding depends on the level of compression needed, but it typically will be a minimum of 10 minutes up to well over an hour.
This means you could take anywhere from 20 minutes to 2 1/2 hours to backup a DVD. This applies to dvd2one as well as DVDShrink or any of the similiar products.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Can't clone DVD with CloneDVD2
By Navop in forum DVD RippingReplies: 4Last Post: 6th Mar 2012, 12:36 -
Best & easiest way to clone a dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 10:00 -
How tp properly clone a DVD using Toast 10
By Jabroni4872 in forum MacReplies: 2Last Post: 28th Apr 2009, 09:25 -
clone dvd 2
By fitos in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 18:16 -
Making a dvd clone..what are my best options please?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2007, 10:51
