Is there any way of including subtitles with this so called faster method? I hate frameserving but as everyone says this is a fast method, I want to try it, I am so tired of flaskmpeg...
Also, I heard there are some problems with fake avi reading in CCE 2.62, if I have to use 2.5 what will I be missing? Is there a quality or speed difference?
First I have to say that I never worked with subtitels. But there are more questions..
I just started with MPEG2DEC and I can say, it is faster. I have got a 30-35% speed improvement.
Definitly it does not work with CCE 2.62.
Using v2.50 you wont miss anything. I worked with both and could not see any difference of speed, quality or whatever.
You can use Virtual Dub filters in Avisynth, hopefully subtitle filters as well. Check the Avisynth homepage. -
I've checked Avisynth site, but it seems that it only allows ocasional subtitles, not like in virtualdub.
So, am I stuck with Flaskmpeg or Virtualdub frameserving?
Anyone knows of a faster way to encode SVCD with subtitles?
I know there is a way of authoring SVCD with optional subtitles (can be turned on or off) but it seems that this only works on standalones and not all of them. I wanted a better solution, with subtitles in the movie itself, not selectable.
People say TMPEGEnc supports subtitles, how? Only through virtualdub frameserving, right? Anyway its dead slow
One method, that work with subtitles (I tested that few months ago) is FlaskMPEG 0.594-> Avisynth1.0(PremierePlugin028Beta37)->TMPGEnc/ CCE.
You may try that, I can't remember, how fast( slow) it is.
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49829&forum=11
<font size=-1>[ This Message was edited by: Truman on 2001-07-11 16:06:05 ]</font>
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
