can I encode Ulead videos into huffy or divx while capturing like in vdub??? The sizes are kinda huge ,800mb for a 30secs video.![]()
Results 1 to 10 of 10
Yes, you should be able to select other codecs in the 'Video Codec' option of the 'Capture Settings' - assuming you are capturing as AVI and not MPEG.
Ulead is particularly good at encoding into MPEG-2 or MPEG-2 provided you have a fast enough computer. I sometimes encode in real-time into MPEG-2 using the DVD NTSC template, and it looks almsot exactly as good as what I get from running Mainconcept outside of real time.
One big advantage of Ulead's excellent video editor is that it has a bunch of real-time encodiing options built in as profiles. Find them under CAPTURE -> SETTINGS -> PROFILES (on my Ulead Mead Studio Pro 6.0, anyway). -
Ulead VS7 IS NOT capable of capturing through HuffYUV codec - INFORMATION FROM THEIR OFICIAL SUPPORT STAFF.
I am a registered user and asked them specifically about HuffYUV, they told me UVS CAN NOT recognize this Codec cause of Hw/sw diferences when capturing;
I haven't understood exactly what they said, but since its from the oficial support and that's what they said, I forgot HufYUV; BTW, I only make rea-time with VS7, no dropped frames, very good quality;
Zetti -
Hi, I am trying VS7, and I am using the Video In on my Asus 9600XT, which has the ATI Rage Theater chip on it. I would like to capture music videos and maybe even movies off of my satellite(bell expressvu), which is supposedly 480x480 res. I am having very little luck finding the right program that won't drop frames.
Maybe I am asking too much from this card, maybe I need a stand alone capture board?
Any help is appreciated.
Thanks -
I have an obsolete AiW 8500DV, and I capture analog realtime MPEG-2 using VS7 - no dropped frames at all.Originally Posted by reckless67
I've realized that othet tools like crap ATIMMC and specially NVE drops lots of frames, so I'd rather stick with VS7;
I capture music at 720 X 480, VBR 6700 Mbps, LPCM audio, try these settings and check....
Zetti -
Zetti, thanks for your reply. I just tried those setting and i'm still dropping frames. Could it be my onboard sound?
Thanks -
Yes......well, there are so many things involved in dropping frames that it's very difficult to point an exact reason......Originally Posted by reckless67
I can't be of much help, all I can say is : don't save money, you have to get from very good to excelent hardware to make proper MPEG-2 recording in a computer;
For example, onboard cards of whatever kind ARE NOT suitable for this task, as a suggestion get a "rated 9 ~10" PCI audio card;
Good luck,
Zetti -
For a user friendly, quick, easy in-sync analog to dvd solution consider looking here:
http://www.adstech.com
from $99 up
jsut beware of early IDVD-1 unit which had a lot of problems, thereby generating a lot of negitive feedback. Had it and gave away. Now have IDVD-2 and is woking great, no sync issue ever.
NO sound when capturing with Ulead SE 11
By TheKillerQueen in forum Capturing and VCRReplies: 41Last Post: 13th Mar 2012, 03:55 -
Capturing sound with Easycap/Ulead?
By lacyxsummer in forum Capturing and VCRReplies: 2Last Post: 7th Dec 2009, 02:07 -
Capturing video files from tv to Ulead Software program
By soccergirl in forum Capturing and VCRReplies: 0Last Post: 23rd Nov 2009, 22:48 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 01:51 -
Ulead crashing
By chewie8008 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 09:57
