I'm going to upgrade my system to P4-1.5GHz. Can anyone advise how much rdram I should install to bring avi-to-mpg encoding time to minimum?
jackosh
Rdram...Pc800 is very fast, so id say that you can get away with 256mb. I dont really do any DVD ripping right now, but just to give you an example on how much ram i use....P3500 -256mb Pc133, P3800 384mb Pc133, P4 1.4 256mb Pc800, AthlonXP 1.53 512mb Pc2100. I really dont see an advantage in getting more ram then 512mb unless you are doing some heavy graphics work
Thks for yr help. I currently use P3-500 with 256mb ram. It takes me abt 8-10 mins to convert 1 min avi to vcd mpg which is way too long for me.
jackosh -
Does ram have anything to do with encoding? I don't thinks so...isn't it your CPU that does all the work. I just upgraded my Ram to 2 sticks of Corsair PC150 256MB CAS 2 Ram. Great for overclocking also....running my 1.2Ghz TBird at 1.333 right now with old PC133 Ram...but with the PC150 CAS 2 ram..should get 1.5 - 1.6Ghz no problem.
256MB minuim with using PC133 if you can, Ideal is 512 of PC133. I am using a 1.2 Thunderbird with 266 bus and 512MB PC133 Ram with great editing power. Make sure you are also using a 30-40 gig hard drive at 7200rpm, you really notice the difference from 5400rpm to 7200rpm.
Value ram
By jollyjohn in forum ComputerReplies: 19Last Post: 5th Mar 2011, 06:21 -
RAM!!
By HotDamn! in forum ComputerReplies: 14Last Post: 15th Dec 2009, 07:43 -
Compatible RAM.
By A Traveller in forum LinuxReplies: 3Last Post: 10th Oct 2009, 10:44 -
RAM upgrade?
By mvp in forum ComputerReplies: 6Last Post: 11th Sep 2008, 00:09 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 11:32
