DVD2VCD is basically a script-controlling GUI shell for a whole bunch of other freeware programs.
Its initial setup allows for DVD, SVCD, or VCD outputs, at least when TMPEG is the encoder.
Now, TMPEG can be set up with its own scripts for XVCDs, for example. Is there a way of digging into or intercepting the DVD2VCD process in order to achieve (non-standard) XVCDs ? Or do I just replace the VCD mcf file in the TMPEG directory with one "doctored" for the features I want, such as higher resolution and higher bit rate, but still using MPEG-1 ?
GK
I've used DVD2SVCD a lot, but I'm not sure if I can answer your question. I would suspect that the template is in the DVD2SVCD program, not in TMPGEnc. I have used the same TMPGEnc program for other encoding and whatever changes I've made have no effect on the DVD2SVCD program. With that said, I would explore the files in the DVD2SVCD folder and you would probably find the template you need. Most of these type of templates are easily edited, even with notepad. Give it a try. Also look in the Doom9 website; What you are asking may have already been done.
Xvid4PSP forcing restart of PC !!!!
By MOLA in forum Video ConversionReplies: 4Last Post: 17th Feb 2012, 03:05 -
m2ts ripping and forcing subtitles-how?
By bigshotceo in forum Blu-ray RippingReplies: 0Last Post: 19th Mar 2011, 10:02 -
Forcing a bitrate with FFMPEG
By boyer in forum Video ConversionReplies: 4Last Post: 3rd Mar 2010, 12:01 -
My DVD is forcing me to have subtitles... D:
By darkzero297 in forum SubtitleReplies: 3Last Post: 30th Jun 2008, 21:40 -
Forcing Aspect Ratio during playback
By hcowan in forum Authoring (DVD)Replies: 1Last Post: 24th Apr 2008, 15:02
