When splitting a MPG flie to place on two cd-rs, the second file to be placed on the second cd-r will not open in TMPGEnc due to unsupoorted format. Also, when i try to burn with roxio vcd the frame rate and size will not transfer. Basically, i have tried raising the TMPGEnc priority and that will not work. How do i get the 2nd split file to carry on the 1st file's traits?? Please help i am lost!
try using a different software mpeg splitter, this happened to me once, i tried a different splitter and it was fine after that.
i found the bolisoft mpeg splitter worked well for me, but you can use tmpgnc to split or cut mpeg files too.also womble. and myflix_xe is a mpeg cutter too.
Splitting audio from a VCD
By Drsin in forum AudioReplies: 2Last Post: 20th Jul 2010, 12:10 -
splitting wmv and mpg at time codes
By silverbullet69 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2009, 03:42 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 13:47 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 22:32 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
