i have converted my divx -
MPG2 format and everything is fine sync is perfect then i authored it and its fine still, but when i burn it (regardless of the speed the sync goes way out)
anyone know what problem is ?
Your synch issue is 100 percent definitely NOT being created in the burn phase of your project. All you are doing there is a data transfer, so if it's out of synch on the finished DVD, your title set is bad. Check your source file(s) for bad frames, improper frame rates, etc. Is it a progressive synch problem or is the whole audio track off, which can possibly be corrected with an offset? Maybe if you provide a little info somebody can help you come up with a solution. Way too many possibilities and your question is far too vague.
ok iam using tmgpenc, encoding into mpeg 2 then using ulead to author it.
everything is fine on oth cases (i havent watched it all through but it works fine every 5 mins) now once i burn it to a dvd (x2) , and play it from the start its all out of sync. maybe its a bad frame causing it when i burn.
but how do i find a bad frame ?
thanks -
Use VirtualDub to scan your source file for bad frames/errors. The synch problem is probably an improper frame rate not just a bad frame, causing it. Again, the burn process is a data transfer of a file that's already been multiplexed so you can eliminate that possibility. It is NOT causing the problem. It is pre-existing.
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 09:10 -
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 05:14 -
Problems with voices out of sync
By Jimbo1 in forum Video ConversionReplies: 4Last Post: 25th Apr 2011, 06:32 -
A/V sync problems with an AVI...
By takearushfan in forum Video ConversionReplies: 0Last Post: 17th Aug 2010, 18:41 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 16:00
