Using TCSV, and Martin's guide, I've had no problem making working VCDs. However, I can't seem to get the intro mpg to play properly. I haven't actually tested a VCD on a physical DVD player, as I test all of my images using powerDVD before burning them (I have enough coasters already). PowerDVD seems to hate any intro mpg I put in, though. I've tried different formats using TMPGEnc, and different intro files, but the audio is always either out of synch or actually crashes the program.
Images I've created work fine once you get past the intro (the rest of the mpgs aren't messed up)
Does anyone have any ideas? Maybe something is wrong with PowerDVD?
BTW, I'm referring to the actual "intro mpg" field on the settings tab in TCSV, not Martin's nested moving menu workaround.
hey whats up
i had the same problem, just got it to work
open your tmpgenc
go to file, mpg tools
go to basic demuliplex, add your mpg as the input
it will give you two files, then go under basic multiplex and put em back together
sounds kindof stupid....but it works
try it, let me know
Many thanks. It worked fine. Sorry for the lateness of my reply (lost the message and only just noticed "My Posts"
16:9 divx movie won't play properly on my TV
By romino in forum Video ConversionReplies: 4Last Post: 22nd Oct 2010, 06:36 -
MPG won't play properly in VideoRedo
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2010, 17:13 -
HDTV2DVD outputs won't play back properly
By papatop in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 10th Dec 2008, 19:45 -
mpg files won't play in IE
By Krispy Kritter in forum Software PlayingReplies: 3Last Post: 31st Oct 2008, 13:42 -
Files that won't play properly in WMP or after conversion
By Trapper Dave in forum Video ConversionReplies: 1Last Post: 3rd Jun 2007, 13:26
