1. First time I've come across this problem. When I choose in DVD2oneX "copy: film" and then follow the correct procedures. When I hit start it only does the first bit which takes about 10 seconds and then finishes. I ran through the procedure about 5 times to make sure I'm doing everyhing right and then tried something else and it worked fine.
In the end I just used the "Copy: Disk Copy" feature. I'm just wandering do some DVDs only allow you to do this? The movie to be precise was "Jackass: The Movie".
2. Also the problem I had creating one file from two DVDs in the end – I couldn't resolve. Just choosing two led me to a file of 4.7 intead of 4.9GB. I am using DVD2oneX 1.2 and I know I've been told to upgrade but would 1.3 make any difference? Is 1.3 the latest version?
it wouldnt hurt to upgrade...
i honestly have NEVER experienced what you are describing
for both your film and 2 dvd experience...
sorry... -
OK - I upgraded to DVD2oneX 1.3 and tried the Jackass Movie and it still only burns the first title (See attached .pdf). The idea is I want to be able to watch the whole film (title 3) + extras (Titles 4 and 5) in one go without having keep selecting from the menus. I know I could copy just the movie but I like the extras. Is there anyway around this where I can get the whole lot onto one DVD???
Originally Posted by kroc_kroc
I'm blind!
i dont see any .pdf?!?!
were you trying to put up a picture?
if so you have to use Preview to export your screenshots as .jpg and then upload that .jpg to your .mac account or other web service before you can host a picture here.
if i read this right you want to have a FILM copy but yet still have all the extras.
to be honest id just do a disc copy becasue the total amount of the menu is not a lot (few hundred megs) and you wont run into any problems like you are.
8mm "film" to DVD
By wado66 in forum Capturing and VCRReplies: 12Last Post: 30th Nov 2010, 16:33 -
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 21:09 -
Questions, re: changes between an "old" and "new" film
By takearushfan in forum Newbie / General discussionsReplies: 11Last Post: 26th Jan 2010, 13:23 -
Can I bypass "copy blocker" to copy from VHS to DVD
By jgloeckner in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2008, 23:40 -
How to copy/convert hidden DVD with only "Track01.cda" in dir
By vincehal in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2007, 06:21
