I've checked the tutorials but none address converting an entire DVD, it's geared mostly for MPEG & AVI (and a few more).
I backed up "The Texas Chainsaw Massacre" and it happens to be PAL. My Apex will play it but my progressive scan Pioneer will not.
Any suggestions on converting or making it work?
DVD video IS MPEG.Originally Posted by ultravista
Rip The DVD, main movie only, to a .m2v and .ac3 file. Follow the guide you mentioned for converting mpeg from DVD to PAL to NTSC. You may need to change the length of the audio to match, not sure how you do that with Ac3 5.1, probably convert to multiple wav files, adjust each one in an audio editor and re-encode.
Then re-author with the new video and audio files.
You will lose all the menus and extras, but that gets the movie done.
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 18:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
