I have a Sony DRU-500a DVD Writer and a DVD-ROM on my seconary IDE channel. On my previous system I has to configure them as Master / Slave. I just recently did an upgrade (Motherboard, Memory, CPU) and, initially, kept them as Master / Slave. However, yesterday I changed them both to cable select and have been running them as such with no problems (so far). My question is simple, which configuration is best?
Just my oppinion, but I always use the master/slave configuration myself
If at first you don't succeed; call it version 1.0 -
The advantage, if there is one, is that cable select allows you to set all drives to cs and uses their position on the IDE cable to determine if they are master/slave. No real difference between the settings as far as I know, just supposed to make things simpler for setup.
I have a Dell computer with XP Pro....everything came from the factory as CS. So when I installed my new LG 4040B Burner....I left it that way and all is running good.
Thanks for all the replies. What I'm hearing is that if your motherboard supports it cs allows one to move drives around and not worry about having to change jumper settings. Other than that, performance is the same.
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 01:48 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 15:50 -
Which Burner for do I set as Master/Slave
By mn072065 in forum DVD & Blu-ray WritersReplies: 12Last Post: 17th Apr 2008, 10:46 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 09:57
