I'm having my wedding shot in DVCPRO by a videographer... I would ideally like to edit the original footage myself and then author DVDs, but it's too expensive right now.
So, my question is, if I have the videographer encode the unedited DVCPRO tapes to DVD MPEG-2 (followed by burning the DVDs) for me, should I have him encode at a particular rate? I would assume 720x480, 29.97fps for NTSC, but should I insist on 6Mbps? 9Mbps?
My goal is to ensure the highest quality transfer from DVCPRO masters to DVD (approx. 10 hours of footage) so that I can later edit those DVD's to 6 hours of footage that I can re-burn to about 3 2 hour DVDs. Will I be able to do this, or should I purchase the DVCPRO master tapes from him and wait till prices really drop and hope somebody will rent me a DVCPRO player for real cheap that I can use to capture to my PC from?
Am I being too obsessive about the quality? Is there a reasonable alternative (ie, transfering them to DV/miniDV tape, etc.)?
thanks in advance,
JR
oh ya.. one other thing..
if I DO go with the DVDs, will I be able to edit them in Premiere without having to spend a lot of time demuxing/remuxing/etc., or is that a whole other issue?
JR -
I've gotten some advice elsewhere to possibly transfer the DVCPRO tapes to MiniDV.
What's the opinion here?
Encoding to BD25 from source: BD-Rebuilder vs. DVDFab
By kILLDR3n in forum Blu-ray RippingReplies: 9Last Post: 4th May 2012, 22:50 -
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 10:35 -
Need filter help encoding the same as a guy did from the same dvd source
By starlight2000 in forum Video ConversionReplies: 10Last Post: 6th Sep 2009, 13:43 -
Installing the open source encoding components
By three-cushion in forum MacReplies: 3Last Post: 25th Nov 2007, 22:07 -
Encoding XVID from 10 FPS source
By dilly323 in forum DVD RippingReplies: 5Last Post: 15th Nov 2007, 01:00
