  1. I've downloaded the 14 day trial for this but when I fire it up I get the message 'Cannot Connect - InterConnect=0'. Anyone know what it means or why I'm getting this error message ? Thanks.
  2. Hmm, never had that one.
    Did you try and go into Environmental settings and moving the directshow up the list to the top? Put VFW second on the list. Also make sure you have a later version of DirectX installed, 7.1 should work but 8.1 definitely works. 9.1b sucks, steer clear, buggy.
    If this doesn't work maybe you should try uninstalling, restart system, reinstall, restart system. If that doesn't work you could have another program on your maching causing a conflict (typical problem). It's a pain in the butt figuring out what program or component is causing problems and sometimes a full clean Windows Install has to be done to fix it.
    Hope this helps.
