iwant to thank martin for the regdrop everything work fine in ur step untiled i got to vfapi step in ur step to check if its workiing rite scroll through the movie only about half of show up other half is blank and i try and to find the problem but now im stuck i used every required program including the new tscv 0.74 still stuck and any advice?
<font size=-1>[ This Message was edited by: Heheheheboi on 2001-10-16 00:33:50 ]</font>
Thread: martin guide problem
are you frameserving it in from virtual dub?
the fact that you can only go half way through the movie is a problem with tscv, this is normally fixed my the frameserving, thats why i have you do it
if you are frameserving, make sure that you are keepin virtualdub open durin the whole process
to tell you the truth, i have run into some problems as of late. i accidentally deleted the program, and since then, i havent been able to get it working again...im currently wiping it from my harddrive and tryin to start over.
however, regarding your problem, if frameserving doesnt help then im not sure what will
i read that if you open the vfapi-avi in media player, and keep it paused, that has helped some people, you may want to give that a shot
good luck, let me know
problem with TV GUIDE on Panasonic DMR-E85H
By ktnwin in forum DVD & Blu-ray RecordersReplies: 10Last Post: 13th Feb 2013, 18:21 -
ricky martin comes out of closet...
By deadrats in forum Off topicReplies: 4Last Post: 4th Apr 2010, 10:37 -
Sony RDR-HX715 and TV Guide - recent problem?
By bjl_avs in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2009, 10:42 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
Problem with the guide for adding subtitles
By AORMan in forum SubtitleReplies: 5Last Post: 13th Jun 2008, 14:50
