  1. Hi I just bought an original VCD of an Indian movie...the discs are not playable on computer...though the VCD player plays them perfectly but i don't have one so I use computer the problem is.......when I tried to browse it in 'My computer'.. it says "Drive E:\ is not accesible. Incorrect Function" and so i m unable to play...i tried it with PowerDVD but no results..
    when i checked the VCD in Nero..it displayed two tracks in Session one
    Track 01: 0:02:00 0:16:52 (5MB) Data(Mode 2) Track 02: 0:18:52 79:22:67 (802 MB) Data (Mode 2)
    Can someone tell me that How can I play that VCD in computer and how the CD was created ?
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    I've run into this problem and the best I can say..maybe someone will add here..due to drive incompatibilities you may see this..thankfully you see the files at all!
    so now I would suggest you extract them from the vcd to your harrd drive ..I think VCD EASY or VCD GEAR can do this...then you can re-burn so its finally compatibible with the computers's drive..sheesh!
  3. Originally Posted by dcsos
    Thanks a lot for the reply but i m not able to browse the files...i can extract the files using ISOBuster but why i m not able to browse even ??
    How the CD was created ?
    Few days ago...I got a pirated vcd which gave the same problem
    what method was used for creating that VCD ??
