Hey everyone! I’m new to this whole AVI to DVD thing, but am pretty good with computers. I’ve been having a lot of trouble converting an AVI I’ve downloaded encoded with 3ivx to MPEG2 with TMPGENC. According to VirtualDub, it runs at 23.976 fps. Mainly, the audio and video is extremely out of sync in the conversion from AVI>MPEG2. I’ve tried exporting an uncompressed PCM audio stream from VirtualDub and using that as the audio source in TMPGENC, but I’ve had no luck. This is the first problem I run into when opening up the AVI in VirtualDub:
I’ve tried this, and no luck. Here’s the properties for the file:
So what do you think guys? How can I work around the synching issues? I've also tried encoding in Cleaner XL, but it still is out of sync! Any help offered will be GREATLY appreciated. This is driving me nuts as the original AVI is perfectly synched. I hope to eventually be able to burn the MPEG2 to a DVD using my new spiffy burnerThanks in advance!!
-Chris
CJLevinsk22
Results 1 to 12 of 12
Have you tried Virtual Dub mod, and saving the audio out as a wave file and muxing it with the original video to see if it stays in synch?
Hello. -
Ok, I'm trying to do as you suggested...but when I open up the AVI file in VirtualDubMod, I don't see any options for Audio. What am I missing?
-Chris
CJLevinsk22 -
I've tried this and still no luck. I can't understand why this is happening?
-Chris
CJLevinsk22 -
I've also tried creating an AC3 file and a seperate MPEG2 video stream and then Multiplexing the two together. This, unfortunatley, produces the same out of sync result.
-Chris
CJLevinsk22 -
How far out of synch is the audio, and is it always out by the same amount?
Hello. -
Tried both of these programs and to no avail. But I did make some progress. I burned one episode to a CD-R, and was able to play it back on the PS2 MediaPlayer as a divx file. So I guess the problem must lie in the transcoding.Originally Posted by Gazorgan
-Chris
CJLevinsk22
Is it worth going back and watching Smallville?
By ryangarfield in forum Off topicReplies: 5Last Post: 22nd May 2011, 15:23 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 15:55 -
Ts Muxer Blues
By romanticwarrior in forum Authoring (Blu-ray)Replies: 3Last Post: 2nd Dec 2010, 09:17 -
XVID to other formats audio blues!!!
By PunkMaister in forum Video ConversionReplies: 6Last Post: 29th Aug 2008, 17:06 -
Windows Movie Maker Blues
By lapetite_66 in forum Newbie / General discussionsReplies: 16Last Post: 23rd Jul 2007, 18:40
Thanks in advance!!
