I am attempting to convert an mpg2 file at 3k cbr to a vbr bitrate using tmpgenc v 12. I had captured the file with the ATI all in wonder Radeon using Power VCR on an XP O/S. I have attempted to convert from 640x480 to 480x480 svcd at a vbr by doing the following:
Kept the file as is - This resulted in a very choppy framerate.
Demuxed/Muxed the file and converted - This kept the file at 640x480 despite the settings.
I have also tried all other versions of Tmpgenc, but it will not allow me to open the source video.
Does anyone have suggestions on converting to a usable SVCD file?
Are you sure that this unspecified conversion changed the file to 640x480? Assuming you have the appropriate directshow filters to playback mpeg2, directshow compliant players (such as windows media player) will automatically resize the video on playback...
As for opening the source video, frameserve! DVD2AVI works with any MPEG2 source, not necessarily DVD. Use VFAPI to load it into v-dub then frameserve to TMPG.
It should be obvious that TMPG, a MPEG2 encoder, isn't going to open MPEG2 streams as input! -
Try flask>>output to bbmpeg. Some ppl say bbmpeg doesn't produce good mpeg2s. http://www.videotoosl.net
Try flask>>frame serve(avisynth or frame-server)>>tmpgenc.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
DXVA for VC-1 & MPEG2 on ATI card. How to?
By nic in forum Software PlayingReplies: 9Last Post: 3rd Jul 2010, 17:33 -
Anyone Have Experience Converting MPEG2 to H.264 with an ATI Avivo Card?
By drstew in forum Video ConversionReplies: 3Last Post: 24th Jun 2010, 11:00 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 14:53 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18
